ChadS
05-02-2005 16:48:12
Re: Git r done! in reply to Just Curious, 04-30-2005 20:26:04
Id have to say by trial and error. Done different things to build compression. What we have done here is how far we are in the story. From what ive seen, and 98% farmall,s it takes a high dome piston, the taller the better. Cant ever get what I want in other piston designs, so I build them myself. Somethings are done, just as I know they will work from others different varaibles that did not work before they built it. I fill in the gaps, if it wasnt enough, I added more stroke. I then started adding parts, like bigger carbs, cams from later production years, listening to all the pullers complain that the carb shop got it wrong,,,, cyl heads, history on what changes IH made to make better engines out of them,, etc etc,, I can go on and on,,, trial and error, looking at worked, and what didnt work,, always looking for changes, I cant cut my own cams to play with cam grinds to know whats perfect. trial and error does that,,,, I build, with what is in front of me,, sometimes,, its not the most tricked out scientific tractor pulling, 25,000$+ engine, it mite be just the neighbors old M,,, but itll run good when it leaves,,,, if it aint got it,, how you gonna get it? spend $$$ and guess,,, or trial and error??? ChadS
