Pulling a JD A
1951G
04-26-2005 17:36:38
I"m pulling with a JD A in 1st gear and am spinning out without any loss of power at end of pull. I was wondering if I pulled it in 2nd gear would it make a difference? It"s got the creeper gear on it. Thanks for any good feedback.
1951G
04-28-2005 07:38:35
 Re: Pulling a JD A in reply to 1951G, 04-26-2005 17:36:38
Thanks for all of the feedback. My problem now is finding a tire to fit my round spoke rims. Do they make a wider tire to fit these without having to buy new rims, hubs, and wheels. I was thinking of 15.5 x 36? I know the ones I have on it now have a little lip left over that's sticking out past the tire, maybe 1/4". Just curious?
1951 A Puller
04-28-2005 06:32:52
Second gear will probably just get you to the spin out spot a little faster. My first year of pulling I pulled with 12.4x38s and realized I was overmatched. My second year I went to 15.5x38s with long bar short bar lugs. It helped some. My 3rd year I went to some Road worn Firestone 15.5x38s with 23 degree lugs and suddenly became competitive. This year I'm using 16.9x34s. Go to natpa.com and click on their rules. You'll see a tire chart showing the "foot print" or sq. inches of various tire sizes...go with the biggest in your weight class and let'er eat. Have fun!!!
twojdpullers
04-27-2005 10:05:02
is your A a straight6 speed &what size tires are you running
Hooked
04-27-2005 06:18:45
Definitely move up to second gear. What are you running for tires and rims? I run 14.9 x 38's on 14" pressed steel rims. Puts a lot a tire surface on the track. I don't have the first reduction gear so I usually have to run first gear which is 2.5 MPH.
1951G
04-27-2005 10:06:39
 Re: Pulling a JD A in reply to Hooked, 04-27-2005 06:18:45
They're 12.4 X 36 tires.
twojdpullers
04-27-2005 10:15:41
 Re: Pulling a JD A in reply to 1951G, 04-27-2005 10:06:39
try firestone 15.5-38 23degree that well help
grandad
04-26-2005 17:47:24
Those As will crack for a long time after most people say oops he is in too high of gear. I would run 2nd and let her buck If it is in good tune it will suprise the ++== out of ya
