Looking for #1 JD-A Powerblock?????
2 Cylinder
05-01-2005 08:38:07
Need to find a powerblock for a 37 John Deere A. Any help would be appreciated.
J.P. Dunn
05-02-2005 06:44:52
 Re: Looking for #1 JD-A Powerblock????? in reply to 2 Cylinder, 05-01-2005 08:38:07
I have a Number 1 Power Block with good pistons and no leaks (currently in a tractor). I would sell or trade the Power Block, Pistons, Rods, Head and Johnson Manifold as an assembly. 573-808-3376 MO
Hooked
05-02-2005 05:58:05
What is the range of years for the #1 A powerblock and the #2? I assume the #2 block is newer. I know where there is a powerblock for an A, I just don't know if it's a #1 or #2 - let me know.
Drew
05-02-2005 10:12:58
 Re: Looking for #1 JD-A Powerblock????? in reply to Hooked, 05-02-2005 05:58:05
A 6-1 will fit a 1934-early 1947 w/ the angle iron frame. A 6-2 will fit a late 47-49 w/ the pressed steel frame w/o creeper gear. A good 6-1 w/ pistons is worth $1200.
Jeremy Brault
05-01-2005 19:27:18
Good Luck, Been looking for a year
J.P. Dunn
05-02-2005 06:48:43
 Re: Looking for #1 JD-A Powerblock????? in reply to Jeremy Brault, 05-01-2005 19:27:18
Give me a call at 573-808-3376. Please leave a message if I don"t answer. Or you could email me at jpsarah@socket.net. Thanks.
