massy 44 need help?
Buford
05-06-2005 19:53:10
I am pulling 4500lb and 6000lb I need more zippp in my tractor what can a poor boy do to get more out of my massey, thanks for any help. Buford
the preacher
05-07-2005 16:52:05
 Re: massy 44 need help? in reply to Buford, 05-06-2005 19:53:10
i have one that i pull, too. i'm actually going through the same trouble. here's what worked for me. get a marvel shebler carb off a MF 65 gas, or a moline G or U. good for 4-5 HP. if you have a dyno, set the timing under full load, and tune the carb the same way. if you set it on the dyno, it will load up when idling, so don't idle for long. shorten the throttle link between the carb and governor so it goes wide open at at least 30 HP load. adjust your no-load with your throttle stop bolt. use autolite 3116's, or champion D21's. if you're serious, port and polish the head and intake manifold. especially the exhaust ports. big power potential there. and get an electronic ignition kit. (i will be ordering one next week)and, try it with a muffler and with a pipe. sometimes a muffler will make a little more power. call me if you have any questions, or just wanna shoot the breeze. 540-439-3677 hope this helps
