case 900 lp
900 Dave
05-12-2005 07:07:57
I would like to change my lp to diesel what would I need to change it over do I need a new head etc.Would like to pull it but don't have any experance with working on a lp tractor.
Thanks in advance
Dave
Andy2
05-12-2005 10:48:22
 Re: case 900 lp in reply to 900 Dave, 05-12-2005 07:07:57
I would leave it on LP. LP is decieving becuase the midrange tourque and lugging power is huge. Putting them on a dyno tells a lot. Filling it is no problem. You can have it filled at most truck stops, get your own LP tank with a liquid line or have the LP truck stop out at their convenience,(around here they don't charge extra for filling tractors). I have the origanal fittings on my MM's and they are the same as RV's and LP vehicals.If you want diesel, sell it and find a diesel.
900Dave
05-12-2005 11:59:53
 Re: case 900 lp in reply to Andy2, 05-12-2005 10:48:22
thanks for the info you guys have been a big help lp is totaly new to me and a little intiminating but I'm more confadent know
Thanks
Dave
jeffw
05-12-2005 07:52:47
i would change it over to gas you would need a tank hood and carb and with the compression a lp has you would have a pretty stout stock puller
jeffw
05-12-2005 07:54:56
 Re: case 900 lp in reply to jeffw , 05-12-2005 07:52:47
also you could just pull it lp a guy is pulling a 560lp in are club and doing great
900 Dave
05-12-2005 08:38:00
 Re: case 900 lp in reply to jeffw, 05-12-2005 07:54:56
Would gas be original equipment, for a stock pull they didn't come from the factory gas did they????
Thanks
Dave
jeffw
05-12-2005 09:06:03
 Re: case 900 lp in reply to 900 Dave, 05-12-2005 08:38:00
im not 100% sure i know the 930 did so i would the the 900 did
jeffw
05-12-2005 09:10:16
 Re: case 900 lp in reply to jeffw, 05-12-2005 09:06:03
to answer your original yes you would have to change the heads and alot more it would probbaly be cheaper to buy a 900 diesel
900Dave
05-12-2005 09:32:59
 Re: case 900 lp in reply to jeffw, 05-12-2005 09:10:16
Thanks Jeff ,I will investagate my gas option sounds like diesil is out.I'm a little scared of the lp don't have a very good way of filling the tank.I don't think the local propane co. is going to fill the tank without a upto date hydro test on the tank. who would do that.Any tips
Thanks Dave
Glen in TX
05-12-2005 14:51:47
 Re: case 900 lp in reply to 900Dave, 05-12-2005 09:32:59
Check with your local LP companies. It will differ some from state to state on the allowable max tank pressure ratings. They should know where to get tank tested also and what is allowable and what needs to be changed. Same diesel engine in 500 and it was only rated at 63HP while the 900 LP was rated at 71 HP. Don't have any books showing a Nebraska test for the 900 with diesel but probably about the same I would think. Only show the 900 with LP and diesel original.
jeffw
05-12-2005 09:49:13
you have to have the valve changed to new style on the tank other than that you shouldnt have any problem getting it filled
jeffw
05-12-2005 09:50:39
 Re: case 900 lp in reply to jeffw, 05-12-2005 09:49:13
where arte you located
900 Dave
05-12-2005 09:53:42
 Re: case 900 lp in reply to jeffw, 05-12-2005 09:50:39
new jersey
jeffw
05-12-2005 10:05:07
 Re: case 900 lp in reply to 900 Dave, 05-12-2005 09:53:42
if you decide to part with it let me know i pull a case 800 gas and i have a case 800 diesel wide front if your interested in a cash/trade
900Dave
05-12-2005 10:20:17
 Re: case 900 lp in reply to jeffw, 05-12-2005 10:05:07
I don't think so not yet,were are you located
Thanks Dave
jeffw
05-12-2005 10:29:29
 Re: case 900 lp in reply to 900Dave, 05-12-2005 10:20:17
maryland
