jd 50 ignition problem
brad thomas
05-15-2005 06:49:57
have a jd 50 with electronic ignition that i pull with. at the last pull , it ran fine until i hooked to the sled. when i pulled off it started running on one cylinder. got home and it had no spark on the right side of the distributor cap. changed wires and plugs but still nothing. could it be the elctronic module, or the cap itself? has anyone had problems with the pertronics ignition? the one i have is part #1121p12. thanks for the help, Brad.
buickanddeere
05-15-2005 17:37:46
 Re: jd 50 ignition problem in reply to brad thomas, 05-15-2005 06:49:57
If the electronics were shot? how would you have spark to one cylinder? Is there any play between the dist shaft and the bushing inside the dist body? Sounds like cap/rotor/wire/plug problem. What plugs are you running and with what gap? What kind of plug wires?
brad thomas
05-15-2005 18:09:54
 Re: jd 50 ignition problem in reply to buickanddeere, 05-15-2005 17:37:46
i am running champion d21 plugs and a standard 8mm wire. should i run a hotter plug? if so what is the size plug i need? i can get a decent size spark out of one side of the cap , and nothing out of the other. i think the gap is set at 0.35 on the plug.
730-LP
05-16-2005 20:07:49
 Re: jd 50 ignition problem in reply to brad thomas, 05-15-2005 18:09:54
I run D23,s at.050 runs great plugs will last all pulling season [30to 40 hooks]
bickanddeere
05-16-2005 20:52:59
 Re: jd 50 ignition problem in reply to 730-LP, 05-16-2005 20:07:49
AC 3116 non resisitor with a 40 thou gap is a good place to start. If the wires are resistor, toss them in the trash and get the real wire core type. Check for the ignition wire seating in the cap. Some cesondary wires don't seat deep enough into the dist cap.
