hard tires
ADroopy
05-16-2005 17:49:30
I have a very hard set of rear tires, is there any way to soften the side wall only.
the preacher
05-16-2005 19:39:46
 Re: hard tires in reply to ADroopy, 05-16-2005 17:49:30
try petrolium jelly on the sidewalls. clean them with acetone first, then spread liberal amounts of vaseline on them. let it soak for a day or two, then wipe off the excess. the acetone will clean all impurities, and dry out the rubber so it soaks up the vaseline better. or, screw the tires to the rims, and drop the air to 3-4 psi. add weight and pull.
