more rpms out of a allis chalmers wd
Big Rigger
05-18-2005 09:54:56
How can i get some more rpms out of a 1949 wd allis chalmers thanks
buickanddeere
05-18-2005 16:04:24
 Re: more rpms out of a allis chalmers wd in reply to Big Rigger, 05-18-2005 09:54:56
Stress is increased 200% by going 141% over rated fast idle. 200% rpms increases stress by 400%.
KBMO
05-18-2005 11:02:45
Replace the governor spring with a heavier spring. Or shave some off the weights. The governor spring is the easiest.
Big Rigger
05-18-2005 11:18:00
 Re: more rpms out of a allis chalmers wd in reply to KBMO, 05-18-2005 11:02:45
what do i replace the spring with from a certain model
KBMO
05-18-2005 11:32:31
 Re: more rpms out of a allis chalmers wd in reply to Big Rigger, 05-18-2005 11:18:00
A 175 allis spring will give it a couple hundred more RPM or just take it out and go to the local hardware store and get one that is much stiffer that is the same size.
