Tire Pressure For 20.8 BFG Radials At 14,000 lbs?
1456 Puller
05-18-2005 22:30:57
How much air pressure should I run on a 1456 IH pulling a 14,000 lb stock class?The tires are 35% tread 20.8x38 BFG Powersaver radials.Thanks.
pcy1066@hotmail.com
05-19-2005 04:16:24
 Re: Tire Pressure For 20.8 BFG Radials At 14,000 l in reply to 1456 Puller, 05-18-2005 22:30:57
as a rule of thumb a good starting point is 1 lb per 1000 lb in a bias tire and 2 pound in a radial, at 7500 we run 7 lb in 23 degree firestone v cuts, on our farmstocker we run 25 lb at 12500
1456 Puller
05-20-2005 23:28:19
 Re: Tire Pressure For 20.8 BFG Radials At 14,000 l in reply to pcy1066@hotmail.com, 05-19-2005 04:16:24
Thanks Paul.
