Re: Alcohol in a tractor
la man
05-19-2005 21:11:26
how so?
la man
05-19-2005 21:15:49
 Re: Alcohol in a tractor in reply to la man, 05-19-2005 21:11:26
in 1/4" hole..... ..0.250" can go through.....in a 1/2" hole.....0.5" of fuel cna goe through it.....
Drew
05-19-2005 21:22:45
 Re: Alcohol in a tractor in reply to la man, 05-19-2005 21:15:49
The cross sectional area of a 1/4 line would equal (using the pi x r^2 formula) .125x.125x3.1415=.049in^2
A 1/2 line would be: .25x.25*3.1415=.196in^2
.196/4=.049
la man
05-20-2005 20:58:36
 Re: Alcohol in a tractor in reply to Drew, 05-19-2005 21:22:45
O....I see, i was thining literal.....double of 1/4 is a half. I didnt' do measuring on my carb, i just used a drill and put a hole in it and it worked. Will work on pure alcohol, or regular gas, its a good carb.
buickanddeere
05-20-2005 08:07:13
Sounds like the carb bowl seat/needle/float was doing the fuel metering at wide open throttle instead of the main jet.
