do they make all ready to run alchol kits for BS
BS
05-20-2005 06:10:45
Looking for an all ready to run alcohol kit for a briggs and stratton 1 cylinder. Is there a place that sells this?? Or if not can anyone build me the kit? Will Pay all costs and then some.
BS
dan m
05-20-2005 18:05:24
 Re: do they make all ready to run alchol kits for in reply to BS, 05-20-2005 06:10:45
what briggs? and what carb? i have done the 5 hp. briggs carbs for go karts, also the tillotsons. can do most any carb if it is do able. takes more than just the jet. let me know if your interested. also need to know what carb we're talking about.
BS
05-23-2005 06:03:01
 Re: do they make all ready to run alchol kits for in reply to dan m, 05-20-2005 18:05:24
Ummm well i know it is a 12 h.p. vertical shaft. Im not sure what kind of carb it is. Is there a name expose to be on it or what?
Thanks Brad
dan m
05-23-2005 19:08:46
 Re: do they make all ready to run alchol kits for in reply to BS, 05-23-2005 06:03:01
does it have a float bowl? is it gravity fed or use a fuel pump? i assume it is a side draft, does it have 2 adjustable needles?
BS
05-24-2005 06:00:54
 Re: do they make all ready to run alchol kits for in reply to dan m, 05-23-2005 19:08:46
Yes float bowl. And it has 2 adjusting needles also. If you think it can be done. How much? O yah it has no fuel pump.
BS
dan m
05-24-2005 19:19:22
 Re: do they make all ready to run alchol kits for in reply to BS, 05-24-2005 06:00:54
yeah, it can be done. wouldn't be much. send me an e-mail and i'll get you an adress to send it to.
JS-OH
05-20-2005 08:03:20
Checkout the kart racing sites and equipment. You can probably use what you have by just getting the right jets. Start at the link below.
