WHAT CAN I DO
BS
05-26-2005 06:11:30
what can i do about this? I mean is there preperations? THANKS BRAD
buickanddeere
05-26-2005 10:38:27
 Re: WHAT CAN I DO in reply to BS, 05-26-2005 06:11:30
Don't over advance the timing, make certain the mixture doesn't lean out at max rpms and max load due to limited carb/fuel system capacity. That 6 to 1 BS is a bit low to take advantage of the 12 to 1 compression ratio E85 will allow. If you try methyl alcohol it will eat through anything aluminium. Always drain and flush the fuel system with gasoline as soon as the engine cools.
dan m
05-26-2005 19:43:52
 Re: WHAT CAN I DO in reply to buickanddeere, 05-26-2005 10:38:27
don't believe all the crap about methanol being corrosive. i have 5hp briggs engines for my karts that sit all winter in my trailer. in northeast ohio. that i can walk up to blow in the tank and they will light and run just like they did when they came off the track last october. if methanol is corrosive why do some suppliers put it in steel drums?
