How to lock differential on 4010???
4010
06-16-2005 13:06:22
Is it possible to lock the differential on a John Deere 4010 without having to go to a 4020 rearend???
JD 4010 puller
06-16-2005 20:28:06
 Re: How to lock differential on 4010??? in reply to 4010, 06-16-2005 13:06:22
I've never had mine not pull positive on all kinds of tracks. Check your tire pressures to make sure they're even. Also, mine weigh's 120lbs. more on the left than the right, you may have to counter balance that. Make sure both back tires are either in the shade or both in the sun. That hot sun will increase tire pressure big time. I assume you have even wear on the tires? Hope this helps.
