small crank jornal
36 A
06-21-2005 18:53:23
Is 2 1/2 inch rod to small.It"ll see light pulling 4500,5500.thanks
jd b puller
06-25-2005 14:49:06
 Re: small crank jornal in reply to 36 A, 06-21-2005 18:53:23
If this helps, my B has about 2.56" journals. A lot of B"s run 2.25" journal x 7" stroke. Sometimes they live forever, sometimes they break. Wouldn"t suggest trying to design the thing on your own, work with a shop that does Deere cranks. You will get opinions on every shop you ask about.
Drew
06-21-2005 19:03:55
Depends on how much stroke. If you are just offset grinding, it would probably work just fine. If going much bigger than that, then I would go with a 2.750". If you get huge with a big bore, 3.000" is probably best. I'm assuming from your name that we are talking a JD A here.
