case 830-930
c hess
06-29-2005 13:59:45
Does acase 831c have achance in 8500lb farm class with regular drawbar -with 200lb on front-3.5 mph linit? Or shoild i get my 930 ready. 830 IS CASEOMATIC WITH 15.5-38-----930 HAS 18.4 34 NEW TIRES
joecool
07-01-2005 05:17:40
 Re: case 830-930 in reply to c hess, 06-29-2005 13:59:45
a 830 with case-o-matic will be in the top of the class in weight classes. you will run out of tire before you run out of motor.
930 have 6 cyl, but 830 will out pull it with case-o-matic.
c hess
07-05-2005 08:04:43
 Re: case 830-930 in reply to joecool, 07-01-2005 05:17:40
Just as you said . ran out of tire just as you said.Trere were some pretty strong farm stock tractors there.
c hess
07-01-2005 06:48:50
Thanks Joe will let you know results pull july-4
charles hess
07-05-2005 08:08:02
 Re: case 830-930 in reply to c hess, 07-01-2005 06:48:50
Just as you said- ran out of tire. There are some powerful tractors in farm stock class. Was a good pull.
