TIRE PRESSURE FOR 7000# CLASS, AND 9000# CLASS.
4010
06-30-2005 06:21:51
I have a 4010 John Deere with Armstrong 20.8 x 38's that I am pulling in the 7000# class for the first time this weekend. Just curious what air pressure I should run in the tire. What air pressure should I run with the same tractor and tires in the 9000# class? Thanks in advance.
Redman
07-01-2005 02:30:34
 Re: TIRE PRESSURE FOR 7000# CLASS, AND 9000# CLASS in reply to 4010, 06-30-2005 06:21:51
rule of thumb has been 1 psi for every 1000 pounds,but i have had no luck with that system.
i run 9 psi in the 7 and 11 psi in the 8500.
4010
07-01-2005 06:39:11
 Re: TIRE PRESSURE FOR 7000# CLASS, AND 9000# CLASS in reply to Redman, 07-01-2005 02:30:34
Thanks for the info Redman. I am not new to pulling, just new to this tractor and weight classes with this tire size. Been pulling 4500-6500 classes for 20 years, and decided to step up to a class with a little less competition, and I always wanted to pull a 6 cylinder diesel.
