Is 1/2 inch too little of a lug to pull with???
770
07-02-2005 19:08:15
I have came across a set of 15.5X38 goodyears...45 degree tires that have only about 1/2 inch of lug in the center that goes out to maybe 1 inch on the ends. The sidewalls are real good...Opinions.....are these going to pull good or do you think there is too little of a lug on them....Curious for opinions....Thanks to all.
buickanddeere
07-02-2005 19:38:54
 Re: Is 1/2 inch too little of a lug to pull with?? in reply to 770, 07-02-2005 19:08:15
I have a set like that. Won the class on the hard clay track. On the loose limestone screenings track they can't carry the loose stuff off the top and dig into the firmer material underneath. About 1/5 of the class out pulled me. Almost all winners there used full tread bar height 45 degree tires.
