o,kspuller
07-11-2005 07:50:38
Re: Bad blood over tractor crank in reply to justmy point, 07-11-2005 06:39:06
give me your email and i will send you pics, and yes i traded to soon should of researched the tractor more, bad trade, the 47 was made to pull 3.5 mile an hour not up against 5 or more , tractor ran ok at the pulls i have 6 1st plases with it i should have never pulled it and check out the crank my fault, the crank was check when i took it out, by a R stanped welder and he said it was cracked already becase of the way the meatal was broken not toren, the welds were not poled into the crank jornals, looked like some bad welding on the cranks part the proublem with this crank was a proublem from the time it was instaled till now, cranks should not be wobling if so there is a proublem out of roundness , so as far a i am concerned is that we both should of not traded so soon, and the guy who did this crank need some more work on doing cranks, the guy i got the tractor from proubly didnt know about the crank and just pulled it he dosnt know much on john deeres not his fault, and yes if there was a proublem with that 47 a i would have made it right , and there was the msd box was burnt up and i replaced it for him,have a nice day mark
