Case Puller
Case311
07-15-2005 17:36:19
What Case tractors would make a good puller that could be modified in the future? Im thinking of getting into pulling. Any help would be greatly appreciated. Im looking to pull 7000# and up no speed limit.Tractor must be mid 1960s or older. Which is better gas or deseil non turbo? Thanks for your help
joecool
07-16-2005 05:15:05
 Re: Case Puller in reply to Case311, 07-15-2005 17:36:19
another thought, if you can run mid 60's stuff. a 970 or 1070, with out turbo, turn the fuel up on the 504 and get alot of power with little expense.
Lamont
07-15-2005 21:13:42
4 cyl Case L and LA can be made to 1000+ cubes. 6 cyl. Case 600, 900, 930 can also go over 1000 cubes. I would stick with gas myself and have always wanted to punch out a 900 Case to 504 cubes. This would be relatively inexpensive and I think with a little intake, carb, head, and cam work would be a 200+ HP tractor.
joecool
07-15-2005 17:55:46
how fast do you want to go? a 800-or 830 gas, diesel or propane with 301 is very hard to beat in stock, low speed pulls, especially with case-o-matic. you can get ALOT of cubes out of a LA
