QUESTION FOR 4010 AND 4020 PULLERS?
4010
07-17-2005 17:38:41
I was wondering what type of air filter is best to use on a 4010 diesel. It currently has the oil bath filter, was told to go to a dry filter. What type do most pullers use? Will a K&N type filter work or isn't that enough volume, would like to keep the filter under the hood.
JD 4020 3020 620 420
07-18-2005 20:52:11
 Re: QUESTION FOR 4010 AND 4020 PULLERS? in reply to 4010, 07-17-2005 17:38:41
I am not sure whats best yet! The JD dry filters can be found, but are scarce and pricey. (If you have the air stack, JD did make a dry filter for a 4020 with the air stack.... I have been told many times they did not) Anyways, I have a 4020 and pull in out of field pulls. I have been using the oil bath air cleaner. But I just made a K&N conversion for the origional canister that still uses the air stack. I have not used it yet for pulling or farm work, so I'll have to wait for a couple weeks and see. If your interested in what I have done to make mine let me know, or I can post here.
