JD G Creeper Gear?
48 JD G
07-20-2005 10:32:49
Does anyone know if there is a creeper 1st gear available for the JD G? Aftermarket? I need to slow mine down for certain pulls so that it can put the power down at the 275-300 foot mark instead of spinning out due to high wheel speed. I'm currently pulling in 1st gear running 18.4-34 Firestone 23's.
too much power
07-24-2005 10:57:58
 Re: JD G Creeper Gear? in reply to 48 JD G, 07-20-2005 10:32:49
If you have so much power, why not just idle it down a tad rather than give up your gear thru the whole run? Or use the brakes, there is one on each side. :)
DW
07-21-2005 04:54:17
I don't know it for a fact, but I've been told that if you put in the 1st reduction gear from a 70 diesel, that will slow down your "G" transmission. Good luck.
