Thanks, Dyno man! Q for ChadS
42Farmall
07-21-2005 18:22:07
Do you know what number size the largest drill bit would be to drill out the main jet on an oversized H engine? I have drilled it out with an #44 but still cannot get it to smoke under load no matter how far I turn out the screw. Thanks for any help.
ChadS
08-02-2005 08:30:31
 Re: Thanks, Dyno man! Q for ChadS in reply to 42Farmall, 07-21-2005 18:22:07
Did you do anything to the metering stem? what # is the venturi, and which carb do you have on your H? ChadS
