Stroke and bore on a unstyled A
38jda
07-22-2005 20:21:20
I would like to build a unstyled A and need some help. I want to go big but dont want to many problems. What is a good stroke and bore,and what is the price to stroke a deere crank. Does any one run the 6.5 inch long block from jerrys,and is it worth $4100. Also what am I going to run for horse power, will it compete with very hot farmal M"s. Thanks for your time.
Drew
07-23-2005 09:47:00
 Re: Stroke and bore on a unstyled A in reply to 38jda, 07-22-2005 20:21:20
A 6.125 power block and a 9.25 crank should be very reliable and make good power. With a good Heisler head, that should make somewhere in the mid 90's for power. In a 3.5mph class you should be competative. In an open class with big Ms, I think the M's will still have quite a bit on you.
As for the block, mine is bigger than a 6.500 Jerrys and cost a he!! of a lot less, but I think his would be more reliable. Does the $4100 figure include pistons/pins/rings? I would stay away from using a Jerry's head on it though.
a puller
07-24-2005 21:09:15
 Re: Stroke and bore on a unstyled A in reply to Drew, 07-23-2005 09:47:00
know of a 110hp G that gets thumped hardcore by M's...and these M's ain't even big..... .so if mid 90's is all, get findin another route if ur gonna pull witht heM's in open classes..... .we tryed that once with our A in an open class..HAHA.....she killed in 3rd, 4500#, and the ol oliver flew through there in damn near road gear and never even labored..... .
