building a wd45 allis
38jda
07-27-2005 18:58:28
Just bought a wd 45 for a puller. Would like to build it big, I can use a d-17 motor or a gleaner combine motor. I pull some really hot Ms,in 4500 and 5500 classes. The rules are make weight and go.I need some help from the allis guys no one here pulls orange, except for me and my brother,and we pull stock class.
KBMO
07-28-2005 05:48:26
 Re: building a wd45 allis in reply to 38jda, 07-27-2005 18:58:28
Definitely start with the D-17/Gleaner E block if you are going big. They are much stronger and have larger mains on the crank. If you are interested I have a motor that is 100+ HP. Balanced completely through including the flywheel. Ported head/big valves,cam,11.5 compression, etc. $4500 Complete. Very reliable proven winner.
AC
07-27-2005 20:17:04
You can go 4 5/8ths by 6, and it will run pretty well. You will run alot better in the 3500lb class. Gleaner motor and d17 blocks work well. Cheapest HP for the buck?
ChadS
07-28-2005 02:21:28
 Re: building a wd45 allis in reply to AC, 07-27-2005 20:17:04
Im not much for AC's, but I do know of one round here that is over 400 cubes, has ran for years, it pulls 3500-6500 with 38" tires and power is not a problem. He can be tough, if he gets it to hook up, it gives M's round here fits when it shows up,,, ChadS
