un. A JD with power block
720 billy
08-06-2005 16:17:52
well i have an A with power block and heiser head with g valves and ported polished and newer crank how much power do you think it has. it has slow reduction gears it was to slow so iput gears out of a 48 A in it would this be the some as the un styld gears. would like to put G pistons in it has any one welded up the heisler head and make it flat around the valves need more power
Drew
08-07-2005 11:04:00
 Re: un. A JD with power block in reply to 720 billy, 08-06-2005 16:17:52
Depending on how well the head is actually working, probably somewhere in the mid 50's on power. The overbore to G pistons will only be worth aprox 3hp alone from the displacement increase. Do you have to run a stock air cleaner? If not, play with the intake tube on a dyno for length and size. A reground cam and roller rockers will help you some, then after that you start to get into the high dollar department.
I dont think welding up the pockets in the Heisler head will do a d@mn thing for you.
