weight of M
Ben Rauls
08-07-2005 18:12:18
I have a 47 Farmall M, am planning on running nine bolt pressed wheels w/15.5x38's, removing belly pump and belt pulley drive. I weighed 5500 before with cast wheels, and belly pump and belt drive? Any idea what i'll weigh, when i'm done? What hubs do i need to run pressed steel? also looking for a sourse for a 450 gas head? Thanks for all the help...
Ben
MDOG
08-09-2005 15:21:44
 Re: weight of M in reply to Ben Rauls, 08-07-2005 18:12:18
I have a 47 M no pump pto lights or fenders just what it needs to pull. With 44 hubs rear 14 inch rims 15.5s 460 post on front w/4:00-15s weighs 4275 w/o driver.
red farmer
08-09-2005 14:38:11
4225 without driver
REDBRAND
08-08-2005 15:35:10
WOULD RECOMMEND WELD ON HUBS.ALOT LIGHTER...DAVE BRUGGER AT 608-762-5517..BROKE 2 HUBS BEFORE GETTING WELD ON'S.THESE ARE WELL MADE WITH THEADED HOLES FOR STUDS...HOPE THIS HELPS
champspa
08-08-2005 14:12:56
some clubs won't let the pressed steel rims on a farmall as one couldn't get them original , check before investing
Ben Rauls
08-09-2005 00:02:14
 Re: weight of M in reply to champspa, 08-08-2005 14:12:56
didnt think of that, mabey will stick with the cast, i have 13.6 now would i have to widen my wheels to run 14.9 or 15.5's?
dej(JED)
08-08-2005 07:46:25
MH 44 HUBS ARE A DIRECT FIT. THEY USE THE 9 BOLT HOLE PRESSED STEEL WHEEL.
jpl
08-08-2005 03:30:03
I have a 52m, 9 bolt wheels, pto off, stripped pretty good, no ps, weighs 4483 with no driver. with me on it have to add weights about 350 for 5000 class, take off lights etc [i could go lower with single frt wheel] if i wanted too.
halfbreedm
08-07-2005 19:16:14
about 4800
FB
08-07-2005 18:34:55
5000
