head gasket for A JD.
720 billy
09-11-2005 13:36:21
i have a head that the valves over lap the edge of block and head gasket need solid copper head gasket or some thing that will work. can make block work with a little grinding it is a power block #1
Drew
09-11-2005 17:24:26
 Re: head gasket for A JD. in reply to 720 billy, 09-11-2005 13:36:21
What head gasket are you trying to use? A $20 Fel-Pro (pn 7744sbx) that I use is big enough to fit over the oversized valves on the POS Jerry's head. So unless your valves are REALLY REALLY hanging out, it should work.
super a dude
09-11-2005 20:38:54
 Re: head gasket for A JD. in reply to Drew, 09-11-2005 17:24:26
what exactly do these fel pro headgaskets look like? steel of fiber? i have been told they are the best ones, but have not looked into them yet....
Mike n Mo
09-12-2005 17:48:42
 Re: head gasket for A JD. in reply to super a dude, 09-11-2005 20:38:54
The FEL-PRO head gasket is a steel sheet on one side and fiber composite on the other. I've never had one blow in 5 or 6 years in using them.The old Victor gaskets were copper/steel sandwiched together. I don't know if those are still available or not. Mike
super a dude
09-14-2005 12:24:06
 Re: head gasket for A JD. in reply to Mike n Mo, 09-12-2005 17:48:42
thank you, i"ve had lots of trouble with the JD ones blowing..we can"t keep them when it gets under a load no matter what we torque the head down to....
720 billy
09-11-2005 18:05:02
it was a JD head gasket the valves are 2 5/8 across face thanks billy
Big jugs
09-11-2005 13:52:05
You must have a Jerry"s head. That's too bad, cause you're gonna regret it. But, anyways, yes, relieve the ring some on the front of your block and measure what you need to clear the valves and order a copper gasket from Lubbock gasket in Texas, I think is where it is. You will need to send a stock one along for the stud hole pattern for them, but a copper gasket can be reused. If someone ever asks you if you want to sell that head....Dump it! Get a heisler and do a little work on it. You will be much happier. Big Jugs.
super A dude
09-11-2005 20:06:58
 Re: head gasket for A JD. in reply to Big jugs, 09-11-2005 13:52:05
do you know anyone who has a jerry's head for sale? i want to play with one a bit..... ..if so, let me know a price.....
720 billy
09-11-2005 13:58:16
 big jugs it isa heisler head in reply to Big jugs, 09-11-2005 13:52:05
it is a heisler head thanks
JDGnut
09-11-2005 14:42:19
 Re: big jugs it isa heisler head in reply to 720 billy, 09-11-2005 13:58:16
Billy... I might have something... I'll send you an email... JDGnut
720 billy
09-11-2005 17:15:18
 JDGnut in reply to JDGnut, 09-11-2005 14:42:19
let me know something or email your phone # and il give you a call thank. Billy
JDGnut
09-12-2005 09:32:18
 Re: JDGnut in reply to 720 billy, 09-11-2005 17:15:18
Billy... I sent you an email.. not sure you got it....
JDGnut
