jd 70 head roller rockers
big jd
09-11-2005 16:28:49
how far can you shave these heads and are murphys roller rocker any good how much power will igain the cam has already ben done looking for alittle more thanks
Lynyrd
10-16-2005 01:30:22
 Re: jd 70 head roller rockers in reply to big jd, 09-11-2005 16:28:49
sedhuh.kulkytetdhertui67lp/knAS33.908l[];led
jd b puller
09-11-2005 18:39:16
Somebody feel free to jump in here, but probably not much if the rest of the engine is stock... They have a bigger ratio so while you may flow better at high RPM, you may lose low end torque. The stock Deere cams usually work pretty good in stock tractors as well. I could be all wet though.
