OT: '95 12 valve dodge
52 A Boy
09-18-2005 18:53:05
Got in my friends truck this evening and went and got something to eat, when we went to shut the motor off we turned the key to the off position but the motor didnt shut off. Anyone got any suggestions
Thanks for any help
52 A Boy
G/MAN
09-19-2005 07:36:52
 Re: OT: '95 12 valve dodge in reply to 52 A Boy, 09-18-2005 18:53:05
I agree it's probably the shutoff solenoid. However, those things are "energize to run", if I remember correctly, so for it to be staying ON, it's getting voltage when it shouldn't be. Usually they fail and won't start at all. The "pull-in" winding fails, and it won't turn the injection pump on, but usually the "hold-in" winding still works, so you can turn the key on, reach down and snap the solenoid in, and then start the truck normally.
Joe Leising
09-18-2005 19:23:19
Sounds like the shut-ooff solenoid went teats up on it. It is located at the rear of the inj. pump kinda under/behind the master cylinder. Not a cheap repair, but an $18 choke cable from NAPA can be made to do the same thing
Joe
JDGnut
09-18-2005 19:47:39
 Re: OT: '95 12 valve dodge in reply to Joe Leising, 09-18-2005 19:23:19
Just some reading.. but after talking to you.. I have to agree with Joe.. Link
Link href="http://www.dieseltruckresource.com/dev/showthread.php?t=73535&highlight=running">Link
Didn't find as many as I thought.. but since it seems to keep running normal.. and not sounding like its the starter that's still engaged... go for the solenoid... first try unplugging it.. (that will tell you if its electrical..) if it keeps running with it unpluged.. its a stuck solenoid.. (most likely..) Good Luck
JDGnut
Sweeper
09-23-2005 18:09:47
 Re: OT: '95 12 valve dodge in reply to JDGnut, 09-18-2005 19:47:39
The solenoid on mine just came apart. It could have gotten hung. I like my Dodge, it took 6 months to give my Chevy 454 away.
