USAP and NATPA rules
Bob4
09-20-2005 17:47:45
Can I take a WD45 diesel and convert it to gas and pull with these clubs?
Gary Baker
09-21-2005 16:49:21
 Re: USAP and NATPA rules in reply to Bob4, 09-20-2005 17:47:45
Bob, You need to go to the NATPA web site and look under rules and what division you are wanting to pull. But I can save you the time and say no you cant do this with the NATPA. #1 reason is you cannot convert a diesel engine to gas. #2 is Allis Chalmers never made a WD45 gas in a 6 cylinder. #3 the engine block must be of the same manufacture, the same length and number of cylinders as stock (gas was only a 4 cyl- diesel was only a 6 cyl.)
We have 2 local guys that did this swap and put side shields on engine to hide engine. They pulled once and got caught and were told by our local clubs they could'nt use this engine any more. If you really want to use this engine pull a D19AC or a Cockshut 40 or 50 were they are legal.
Hope this helps
sos puller
09-22-2005 03:55:44
 Re: USAP and NATPA rules in reply to Gary Baker, 09-21-2005 16:49:21
you can't use the d19 engine in a 40 or 50 cockshutt for natpa. or i was told so, but maybe ask the boys from nebrasks.
Heavy Puller
09-22-2005 04:51:38
 Re: USAP and NATPA rules in reply to sos puller, 09-22-2005 03:55:44
You can use that engine in a CS 40 or 50 in DIV 3 but not DIV 2 according to the Nebraska Mafia.But as far as using it in a AC wd45 I have yet to see any clubs allow it in other than open classes.
Read Div 5 Rules
09-21-2005 19:49:46
Can be done but only in Div 5. Rule 11 says diesels can be converted to gas. D19 engines or combine engines are the same length of engine as the original diesel. The biggest problem is making enough cu. in. Olver 88 and Farmall 460 are the tough ones to run with.
JOHN LAMPKIN ---USAP
09-21-2005 04:57:07
THE WD45 DIESEL HAD A 6 CYLINDER MOTOR IN IT FROM THE FACTORY. BUT THEY NEVER USED A 6 GAS ENGINE UNTIL LATER IN THE AC GROUP. SO IT WOULD BE CONSIDERED A HYBRID TRACTOR OR A PARTS TRACTOR. WE ALLOW TRACTORS TO CHANGE PARTS AND ENGINES MOTORS AS LONG AS THEY DO NOT NEED ADAPTER PLATE TO MOUNT. SO NO ON THIS CONVERSION. IF YOU NEED TO TALK CALL ME 270-929-5669
Bob4
09-21-2005 15:21:45
 Re: USAP and NATPA rules in reply to JOHN LAMPKIN ---USAP, 09-21-2005 04:57:07
We would use a wd diesel block and D19 head. This wouldn't be any different than what the GBD Molines are doing? We were just wanting to pull in some lighter classes and thought this would be a cheap and easy way of doing it. thanks
A.P.
09-21-2005 12:09:38
I am probably wrong, but I thought the head from a D19 gas tractor would bolt to the WD45 diesel block. If so, no adapter plate would be required. Wouldn"t that make it legal. Maybe I am missing the point and they want to bolt in a 301 Allis engine.
SPT
09-21-2005 05:01:13
Darn, I was considering the same transplant.
