Junkman10
Cases n Harleys
09-27-2005 19:42:17
Hello Junkman10, I was just browsing through some of the post & happen to read your post about the 90 degree drive distributor,I can honestly say that when I build these Harley Davidson engine up the first thing I do is file 13 the factory electronic ignition, and replace it with a Crane Hi-4 single fire ignition, that alone with stock compression,stock cam,&stock carb does make a difference that is noticeable,easier starts,crisper throttle response, and better fuel economy. That extra 10,000 volts does make a difference even though it's not a race engine. Just My two cents, Good Luck.
