MW Dyno gauge repair
Agco Avenger
09-29-2005 19:58:37
Hello, I need to find someone who can repair the Pressure/HP gauge on my M&W dyno. It is stuck and won't return to zero. Thanks
Mike S 806/H
09-30-2005 22:49:01
 Re: MW Dyno gauge repair in reply to Agco Avenger, 09-29-2005 19:58:37
Bristol Babcock inc, (860)945-2442 I had mine rebuilt and calibrated for around $140.00
Pete1468
09-30-2005 18:36:56
I can repair horsepower guages for M&W dyno"s. Drop me an email and we can converse.
BigBen
09-30-2005 13:32:08
I dont know of anyone that repairs that kind of gauges, but if its just a pressure gauge that has a face that reads in HP it isnt very complicated. Just take it apart make sure there is nothing binding (it dosent take much rust to stop the action)and maybe put a little wd40 on it and makesure there is nothing broken. then there should be a zero adjustment on the needle if there isnt just carefully pull the needle off and reposition it. then if you get it working again you will need to compare it to a know standard in order to get a accurate reading. if it is off you can adjust linearity by the adjustments inside or bendind the tube inside slightly.
Ive worked on hudereds of gauges for the Marine Corps so if you have any more questions email me
