compression lbs. ver. comp. ratio ????? HELP
1morgan
10-20-2005 18:38:29
If comp. was 250 lbs. what would the ratio be ? THANKS FOR ANY INFO.
buickanddeere
10-23-2005 06:21:01
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to 1morgan, 10-20-2005 18:38:29
Cranking rpm, air temp, humidity, valve timing and volumetric efficiency are all factors that must be considered.
jd b puller
10-23-2005 14:17:02
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to buickanddeere, 10-23-2005 06:21:01
B&D - is it reasonable to ESTIMATE about 20 PSI per CR? just to get you in the ballpark?
Drew
10-23-2005 15:40:16
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to jd b puller, 10-23-2005 14:17:02
Not really. On my tractor a few years ago, the head/manifold/carb was changed, dropped THREE compression points.....ended up w/ the same cranking psi. There is NO way to compare cranking psi to mechanical comp. ratio.
Rahlo
10-23-2005 19:42:32
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to Drew, 10-23-2005 15:40:16
Drew, you hit the nail on the head. I have been a mech and eng builder for over 20 yrs and I get the same ? put to me. I get a lot of odd looks when I tell people that I have seen 6 to 1 engines pump 250psi and I've seen 10 & 11 to 1 engines pump 225psi. You cannot compare the 2 comp ratio and PSI.
psi
10-21-2005 11:13:21
psi isn't relevant to ratio. to get a ratio, you need to CC your motor. just do a compression check and see how many psi you have. depending mainly on your bore and head design, you can tell how many octane you would need to run. if it was a moline with a 5" bore and 200lbs of compression, you could run it on 94. if it was a JD A or G with a 6.125" bore, and 200lbs of compression, you would need 105 or more octane to run it.
Rahlo
10-23-2005 19:58:51
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to psi , 10-21-2005 11:13:21
I'll have to dispute your theory on that. You need the compression ratio still to burn the higher octane fuel. If you have a 6.5" bore or a 3" bore it will make no differance, if both engines are 6 to 1 compression you still need lower octane fuel just a larged fuel charge in the larger bore engine per cylinder. If the 3" bore engine was 10 to 1 you need higher octane to produce a slower ignition and a longer burn time.
BM
10-24-2005 19:36:56
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to Rahlo, 10-23-2005 19:58:51
Don't forget, combustion chamber shape and quench area make a big impact on what octane rating you can run.
psi
10-25-2005 11:31:07
 Re: compression lbs. ver. comp. ratio ????? HELP in reply to BM, 10-24-2005 19:36:56
exactly..thanks BM
