stroking a 44
44MH
10-22-2005 10:48:24
I'm starting a stroker engine project this winter and since most of my pulling background is IH anybody got any ideas on stroking a 44 Massey?I've been told to use H Farmall rods and offset grind the crank but I don't want this to be a screw up so I'm trying to get ideas.I'm thinking maybe a 1/2 inch or so.Thanks for the info.E.S
Masseypuller
10-25-2005 14:14:37
 Re: stroking a 44 in reply to 44MH, 10-22-2005 10:48:24
If you are only going to 6", then I would use the stock rods and save the expense of buying others. To use stockers with 6", you only have to machine down the head of the "outside" rod bolt.
Regards,
Masseypuller
Doug Baumann
10-24-2005 04:39:06
If you would like, I could send you the spec's we used for our 44 Massey. We stroked it a 1/2" along with boring. We also made some carburation changes and are currently runing at 95 h.p.
BushogPapa
10-23-2005 18:08:08
My 44 is a Magnum....I think stroking it makes it a 454 Casull....Powerful Stuff..... !!!!
Ron...
BushogPapa
10-23-2005 18:08:42
Ron...
BushogPapa
10-23-2005 18:09:01
Ron...
BushogPapa
10-23-2005 18:09:03
Ron...
gumpster
10-22-2005 18:01:42
I used Farmall M rods in a recent project. 6 inch stroke with aries pistons. Makes 326 ci.
gump
