wiegh of a 560 farmall
brian IH
10-22-2005 14:40:40
How light can I get a 560 Farmall/TA ? With pressed steel wheels and a light front end pto removed as well. Also what is the ground speed for first gear?
thejdman01
10-23-2005 12:36:06
 Re: wiegh of a 560 farmall in reply to brian IH, 10-22-2005 14:40:40
diesel?
jpl
10-23-2005 05:14:39
there you go i have the heavy wheels, so you will get down to steves weigh.with pressed wheels. jerry in ohio.
jpl
10-23-2005 05:09:00
my 560,with pto and fasthitch removed, with custom drawbar and wheely bars with no driver,no fenders. weighs5510. first gear in operators manuel shows with 15.5-38 at stock rpm;s to be 2.2 thats for farmall 560 international 560 are different. this speed is at 1800rpm. hope this helps you jerry in ohio.
Steve in OR
10-22-2005 14:48:34
Mine weighs about 5300 without weights and driver. It has narrow front, 18.4 x38 on pressed steel, large flat top fenders, light seat, and no pto or fast hitch, custom draw bar. I haven't been clocked in 1st gear, in second I was clocked at 7.5 mph going down the track (It runs high rpm).
Steve
