e85----e85----e85----e85-----e85 wow
b barenie
10-28-2005 19:46:46
C ALOT OF STUF BOUT E85, DON'T K-N0 MUCH BOUT IT.
GIVE ME A WEEK AND ILL TELL YOU WAT IT REALLY IS !
LOOK FOR VERY SERIOUS INFORMATION ABOUT OCTANE, E85 AND COMPRESSION RATIO'S NEXT WEEK.
Doug Boll
10-31-2005 13:26:27
 Re: e85----e85----e85----e85-----e85 wow in reply to b barenie, 10-28-2005 19:46:46
Some friends have tried it, works good in one puller, pings in the other. Neither is quite stock. I would like to try it, cheaper than race gas, haven't quite had the nuts to do it without more research. I say use it, if it works, too much corn around anyways! Should not be allowed to be injected except in the wildcat classes.
J. Banet
11-02-2005 00:04:31
 Re: e85----e85----e85----e85-----e85 wow in reply to Doug Boll, 10-31-2005 13:26:27
First, you'de have to mix it with gas and since e-85 is 70% alchol, you end up using 3 x's as much fuel. You would also have to have way bigger jets plus with the heat factor I doubt it would be worth messing with when its easier to use 110 racing fuel and have the same octain every time. If you want a little extra put a little "Heat" gasline antifreeze in your fuel It will burn way hotter.
