h on diet?
brandonf
10-28-2005 21:20:31
how much weight will I lose if I get rid of the hyd pump and the belt pulley? if I lose the hyd pump do I need to girdle the bellhousing I beleive its called? thanks brandon
Brian in Ne
11-01-2005 17:00:21
 Re: h on diet? in reply to brandonf, 10-28-2005 21:20:31
The belt pulley ass'y is worth about 75 to 80
lbs. and the belly pump about 150. Yes you do need the block off plate in place of the belly pump, as the tractor could split in half. You can
make one out of 1/4 in plate.
brandonf
11-01-2005 20:08:56
 Re: h on diet? in reply to Brian in Ne, 11-01-2005 17:00:21
since I am on the subject what is the lightest I could get her down to I assume used pressed steel wheels. Where else is there to shave weight? I am letting my boy drive it at 130 lb. btw thanks for the response brandon
