tubless tires
1morgan
11-03-2005 19:06:33
Can tires like a 15.5-38 be run tubeless with good rims ,and ifso how would you mount them????
showcrop
11-06-2005 17:56:55
 Re: tubless tires in reply to 1morgan, 11-03-2005 19:06:33
I run 15.5-38s on my ford, I had problems at first with them coming off the bead below 7 psi but after a few pulls at 8 psi or over they seemed to be OK. if I were you I would use bead sealer to be sure.
Travis M
11-05-2005 06:08:24
I run them on all my pullers, just use some ether, or starting fluid, spray some in the tire, and get ready to put the air hose on right after you light it up, blows them right on the rim, its pretty easy
BENCIE
11-04-2005 17:55:48
I RUN 15.5 TUBLESS ON MY M. USE LARGE BASE VALVE STEMS. SOMETIMES GO AS LOW AS 7PSI DEADWEIGHTING 6500LBS AND HAVE NO PROBLEMS.
BENCIE
11-04-2005 16:30:43
BENCIE
11-04-2005 16:29:15
