White Pine Tn. Tractor Pull Nov. 19
1066
11-10-2005 20:16:23
Are you pulling Farm Stock? If so i need rules and directions.Thank You.
ETATA
11-14-2005 04:57:06
 Re: White Pine Tn. Tractor Pull Nov. 19 in reply to 1066, 11-10-2005 20:16:23
The classes actually start at 3000 pounds and go up from there. The biggest thing is in the 4mph class, there are no cut tires allowed and the tire size is 16.9x38 on a 14 inch rim. Tractors 1959 and older, no turbos. The pull is all indoors. Email if you have questions. Thanks
1066
11-12-2005 20:41:53
I guess every 500lbs starting at 3500lbs weight brackets,do not know for sure.Thanks
1066
11-11-2005 19:33:07
Can you tell some of the antique rules?Thank You
WEL
11-11-2005 12:21:37
The directions are as follows: Interstate 81 in east Tennessee to exit #8 (Highway 25E)Go south toward White Pine, TN for less than a mile to Walters State University Expo center on the right. This is always a good pull and the facilites are very good. There are several motels and resturants at the I-81/25E intersection.
DEERE CRAZY
11-12-2005 17:16:11
 Re: White Pine Tn. Tractor Pull Nov. 19 in reply to WEL, 11-11-2005 12:21:37
I KNOW SOME OF THE RULES LIKE 16.9 IN ALL CLASSES, ANY GEAR, ARE THEY ANY THING ELSE THAT IS IMPORTANT I NEED TO KNOW? THINKING OF COMING UP TO PULL
730-LP
11-12-2005 18:15:32
 Re: White Pine Tn. Tractor Pull Nov. 19 in reply to DEERE CRAZY, 11-12-2005 17:16:11
4MPH in classic and 12MPH in open gear, max. draw bar 20" high,18" from the center of the rear axle,front weights 11 ft from the center of the rear axle, wheelee bars required,no tolarance on weight
