460 diesel
Casey Youngerma
12-01-2005 19:19:28
New to antique pulling and need to get info on parts, aftermarket parts, and whether a 460 is even worth messin with.
Jak
12-05-2005 07:44:01
 Re: 460 diesel in reply to Casey Youngerman, 12-01-2005 19:19:28
I know a Casey Youngerman here in West TN,that ain't you is it?Just about any of these old tractors are worth messin with.Go for it Casey,and if you want to really pep it up there are combine engines that will fit right in there,maybe a Red Diamond truck engine,lots of potential.Jack(TN).
another 460 puller
12-04-2005 20:18:47
The bad part of pulling a 460 is after awhile nobody likes to see you show up at a pull. Don't be upset when nobody talks to you just because you whipped everybody there and whipped them bad too.So just have fun and don't worry about what they say.
migraine
12-01-2005 20:11:52
I pull a 460 diesel with 282 cu in bored 560 motor with 560 crank, roosa master pump off 756 opened up and ground out the stops , balanced and running 3200 RPMs with 16.9 38 tires (for next season) in third direct should run at about 10 mph. Parts are very available and I woould recommend a heavy duty TA and Heavy purple spring clutch and go have some fun. Yes I have had it apart a few times mostly head gasket but went to Victor gasket and shes been steady for a long time now. I also pull a 560 diesel in stock class and it does ok but both are hard starting suckers. Migraine
