The right size Tire???
1morgan
12-02-2005 21:07:09
Iam trying decide to use either 15.5x38 or 16.9x34 tires on my W D . Have been running 15.5 38 this summer. I have plenty of power for these. Mybe 16.9x34 would do better, any suggestions from you pro pullers? Thanks Much with any Help.....
RCP
12-03-2005 07:07:30
 Re: The right size Tire??? in reply to 1morgan, 12-02-2005 21:07:09
We had been running 15.5's and switched to 14.9's a little taller and more sidewall, also heavier. But I am very glad we changed to them, the 15.5 appeared to be so stiff that they wouldn't conform to the track, basically like running a rolling pin across the table. We tried playing with air pressure but couldn't seem to find a difference. So for us the taller sidewall appeared to be better.
slowsmoke
12-03-2005 04:51:06
15.5/38 is the same height as a 16.9/34, 4" more side wall. not sure how they'd do in a lighter weight class I run the 34's in 5500/up and find they're more picky about air pressure. if you live by the extra sidewall, you die by the extra sidewall. don
buickanddeere
12-03-2005 06:49:18
 Re: The right size Tire??? in reply to slowsmoke, 12-03-2005 04:51:06
Amen large dia rims and short sidewalls win.
