powerblock
bm3501466
12-06-2005 16:48:08
What are the horsepower and torque specs for a powerblock for a JD B? What is the maximum load for a rearend on B before things start to fly apart? Thanks
jd b puller
12-06-2005 19:32:51
 Re: powerblock in reply to bm3501466, 12-06-2005 16:48:08
Stock HP was about 26, with a powerblock and a little extra compression you will be around 35HP. When mine was like this, it would pull 2nd gear in 3500 on good track and had to go to first for every other class. If it was a loose track, it would run 2nd in 4000# class. It's a pressed steel frame tractor so it has the creeper low gear. Could run in 5500 without powering out in 1st gear. You won't be able to compete in 1st gear any more. Too much competition. Send me a phone number and I'll give you a call.
blackwidow
12-06-2005 17:22:30
we have a b jd in our club that pulls up to 6500 with no problems
