MM 6cyl Diesel, worth messing with?
mm diesel pulle
01-04-2006 13:07:57
I have been told that 504 diesels cant be built. I am lookin for upwards of 200hp and several people have told me to just get a gas motor because they can be built cheaper and it would be easier to get the power I want, has anyone had luck building a diesel?
Dieselbear
01-05-2006 03:04:18
 Re: MM 6cyl Diesel, worth messing with? in reply to mm diesel puller, 01-04-2006 13:07:57
Sure they are! Just remember airflow and pump work
mo4xdadad
01-04-2006 17:05:45
Yes they are worth messing with. I would recommend starting with a 585. They are easier to work with. Their are also those that have worked with them and know the shortcuts. What classed do you want to pull in? There is a lot that can be obtained by pulling a minnie. However, gas or lp is easier to mess with. My recommendation is lp for two reasons, pressurized fuel, no worry for fuel pumps and 2nd it is 135 octane most of the time. It all depends on how much a guy can withstand in the pocketbook.
mm diesel puller
01-05-2006 14:04:49
 Re: MM 6cyl Diesel, worth messing with? in reply to mo4xdadad, 01-04-2006 17:05:45
I want to pull 7500-9500, its basically an open class with a 3000rpm limit, a mm guy in ohio that has several mm pulling tractors said that you cant get enough air into the 504. The standine pump we have on it will move plenty of fuel so thats not a problem. I would also like to figure out some specs for a cam for a 504 or a 585.
G/MAN
01-06-2006 10:37:10
 Re: MM 6cyl Diesel, worth messing with? in reply to mm diesel puller, 01-05-2006 14:04:49
Is that engine equipped with "Power-Cells" or precombustion chambers? If so, that may be a major stumbling block, as precombustion chamber engines don't easily lend themselves to big power - look at a 6.9/7.3 Navistar or 6.2/6.5 GM diesel, for instance. Nobody was doing much hot-rodding of Ford and GM diesel pickups until they brought out the direct-injection Duramaxes and PowerStrokes.
Doug Boll
01-04-2006 14:53:06
put on some 504 Case heads (direct injected) and turbo it, should run like a cut cat!!!!
Doug Boll
01-05-2006 14:32:18
 Re: MM 6cyl Diesel, worth messing with? in reply to Doug Boll, 01-04-2006 14:53:06
The Case heads will remedy your air flow problem!
AC
01-05-2006 19:15:56
 What am I missing here? in reply to Doug Boll, 01-05-2006 14:32:18
504 CASE heads on a moline? How does this work?..andy
Doug Boll
01-06-2006 05:00:33
 Re: What am I missing here? in reply to AC, 01-05-2006 19:15:56
drill bits, thread taps, ingenuity and hard work! It isn't a bolt on deal but was told by a Minnie guy it can and has been done. I suppose the only other option would be G1355 or 2-150 stuff, they're direct injected aren't they?
AC
01-06-2006 14:43:17
 Re: What am I missing here? in reply to Doug Boll, 01-06-2006 05:00:33
I don't think the 585 is direct inject, guess I gotta ask Mopower...I know you can put a Cat or IH injector in one, but thats the extent of my knowledge..I know where there a set of 504 Case heads laying around...thanks, Andrew
G-1000
01-06-2006 16:00:36
 Re: What am I missing here? in reply to AC, 01-06-2006 14:43:17
The 585 MM is direct injection.
