help
560puller
01-08-2006 22:57:51
do any of u guys know any other sites i can go to to get info on a 560 2 make it a good pullin tractor
ejr-IA.
01-09-2006 16:48:42
 Re: help in reply to 560puller, 01-08-2006 22:57:51
Yes late model 282,301.
ejr-IA.
01-09-2006 12:39:54
Try to get the head to breathe better,porting,bigger valves.Could pull the sleeves and add the bigger 301 pistons for more cid.Put the later IH midgett injectors in,could put a bigger head on the injection pump 370 like off a 806 pump or use a 806 pump their governed for 2400 rpm.and it bolts right on.
560 puller
01-09-2006 13:29:37
 Re: help in reply to ejr-IA., 01-09-2006 12:39:54
where could i find these midgett injectors at they a dealer item r they off a 706 and newer models
560puller
01-09-2006 13:25:28
thank u ejr-IA 4 ur info
Mcred
01-08-2006 23:27:49
normally this fourm is an ecellent source of info but for the last three days it has been nothing but a big cat fit between two female tractor pullers and either of them will seem to give it up. I'v got a friend of mine going to build a 560 for pulling here fairly soon and he wants to bore the block enuf to fit 806 pistons in the block just to get it out and then he wants to take a 301 combine moter that he has and bore and stroke it for more power.
560puller
01-08-2006 23:47:25
 Re: help in reply to Mcred, 01-08-2006 23:27:49
thanks mcred is his a gas are diesel the 1 im wanting 2 build is diesel.
Mcred
01-10-2006 14:20:54
 Re: help in reply to 560puller, 01-08-2006 23:47:25
His is gas, but them diesels can run pretty hard too good luck and let us know how it turns out.
