Injectors and Line size Recommendations
4010 pullin
01-13-2006 09:07:08
I have had the injection pump spruced up and a 390 head install on a Stanadyne rotary to flow more fuel. Have a M&W turbo kit on the tractor with the stock turbo for a 4010, also have a turbo that is considerably bigger. Which size injectors and lines would work best? Tractor is stock 4010 with 4020 kit, only used for pulling, running 2750 to 3000 RPM range in 7000-10,000 classes.
ejr-IA.
01-13-2006 19:46:41
 Re: Injectors and Line size Recommendations in reply to 4010 pullin, 01-13-2006 09:07:08
You probably will want to take the charge pump out and put a rotary pusher pump instead or you will be twisting pump shafts right and left.
856 puller
01-13-2006 09:58:43
we run a 450 head & rotar with .093 lines and .035 tips. i dont know how mutch fuel you are pushing with the 390 but you might as well get the bigger lines and tips now because you will want more fuel sooner or later. i have worked with steve at stjoes he has been a big help
minnesota red
01-13-2006 09:50:11
call midwest diesel injection,in Ft Dodge IA.
talk to lee,i don't think you want to take advice from anyone in this area,the wrong size line and injector will seize the pump head.
