More pep out of a series 100 pump
Braunvieh Farms
01-14-2006 20:09:13
What can a guy do to a Series 100 pump on an IH to get a some more fuel out of it I have heard about some valve that you can open up but haven't actually seen it done. Thanks
Aaron
Morgan 1066
01-14-2006 21:11:34
 Re: More pep out of a series 100 pump in reply to Braunvieh Farms, 01-14-2006 20:09:13
Cut the lip off the top of the delievery valve. Shim up the fuel pump presure spring with about a 0.040 shim. This will get ya probably 50 h.p at least. But it will not run right in the field then, it works great for wide open under load. I thought I told you this in a previous post. If you really wanna just git with it, just go and buy a 13mm pump.
Braunvieh Farms
01-18-2006 17:48:31
 Re: More pep out of a series 100 pump in reply to Morgan 1066, 01-14-2006 21:11:34
Where might this be located is it in the head of the pump itself or elsewhere, I am having trouble finding it in my support Pro program. it shows the pump and the lines but no delivery valve.
Thank you for your time and help
Aaron
