heads
38jdhaypress
01-16-2006 10:06:42
Which would be better if you had a choice, a Farmall 450 gas head or a Farmall 400 LP head?
randy hall
01-16-2006 16:07:31
 Re: heads in reply to 38jdhaypress, 01-16-2006 10:06:42
you need casting numbers to be sure. only the later 400 lp's came with the 364586 head. the earlier ones came with the same head as the gas tractors 362174.
champspa
01-16-2006 10:33:06
the Lp head has high compression due to fewer cc's
