MM 206 OVERHEAD valve rod length and deck height
AC
01-16-2006 17:38:24
Can Anyone tell me the deck height and rod length for a MM 206 series engine with the OVERHEAD VALVES, that came out of a 445. Is an HD 220 (U302 gas) any different?
I want to offset grind my 206 crank 5/8ths of an inch (should put me at a 2" journal) and I am trying to figure out what kind of rod I can shoehorn in there to make it work. I am just building a $CHEAP$ motor.. ANY IDEAS? I have too many projects apart already.. thanks, Andrew
LW
01-17-2006 16:12:08
 Re: MM 206 OVERHEAD valve rod length and deck heig in reply to AC, 01-16-2006 17:38:24
Stock rod length 9" c to c, deck height 13.6, Good luck finding a rod that long with a 2" journal, Billet or welded, I would go with the first choice.
