More power for a Farmall M
CTS
01-25-2006 18:56:34
Hi Guys, What can you do to get closer to 100Hp without a big $ stroker crank ?
ChadS
01-26-2006 18:03:31
 Re: More power for a Farmall M in reply to CTS, 01-25-2006 18:56:34
You wont get no where close to 100 without a stroker. 80, yeah,,, but it will take a good head and cam, carb and intake. 281's in stock form (rebuilt of course) is a tad over 60, some get lucky and get more,, M's lack torque,,, the SM-450 has more from the changes they made to them, heavier flywheel, bigger clutch, better cam, head, intake, carb, and a heavier casted block. if your rules allow, and you want to build a good engine, start with a C-264-281 long block. They are outhere, and can be bought reasonably. Get the flywheel and clutch too. That makes a good set up for a M, and you can modify it from there,,, Ive seen 264's in the 70+hp with a LP head,, but was awfully high compressed, almost too much for the cubic inch. Strokers are the best way to go, they are not that expencive, bout 1000-1500 more VS a stock rebuild. JMHO,, Chad
SM-53
01-26-2006 16:20:28
I THINK YOUR QUESTION HAS BEEN ANSWERED !
superih
01-26-2006 15:01:05
Buddies M with 6 1/4" stroke 4 1/4" bore ported 450 head and manifold, stock carb, pertronix ignition dino'd 92 horse on his M&W dino, I did witness it. Take it for what you will.
Flogger
01-26-2006 14:12:21
There are more than a few well built, well tuned Ms out there that have the stroker, good head, cam, carb, etc, etc and still making less than 100 horsepower. Unless your turboing or supercharging it I'd say forget it.
W.B
01-26-2006 13:10:39
I got one of chads kits in my 450 and i got exactly what he sais i would. My buddy also got the same kit from him and again got exactly what he said we would. I"ve been seeing people doubting chads kits but take it from me, he aint no denny"s carb shop.
CTS
01-26-2006 14:30:58
 Re: More power for a Farmall M in reply to W.B, 01-26-2006 13:10:39
W.B What is in one of chad s kits ? and how much Hp did he say you would get ?
W.B
01-27-2006 15:00:10
 Re: More power for a Farmall M in reply to CTS, 01-26-2006 14:30:58
I got a piston kit from chad with off set wrist pin bushings. He guarnteed me 70 horse. I ended up with 73.
SM-53
01-26-2006 05:41:07
You don't
half breed m
01-30-2006 18:51:24
 Re: More power for a Farmall M in reply to SM-53, 01-26-2006 05:41:07
well sm 53 sorry to break your hart but i was thier when the tractor was checked how can you say what it has and what it dont if you were not around !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!
CTS
01-26-2006 06:06:20
What Do you mean you Dont! Theres Super M s with an oversize kit at 281cid thats 60 Hp without a thing elese done to them! I Guess i am asking How much can be made by boreing a super m block out and useing a custom pistion and useing a 400 or 450 head thats ported etc to get the most out of it?
5 letter words
01-26-2006 12:05:03
 Re: More power for a Farmall M in reply to CTS, 01-26-2006 06:06:20
You need a 5 letter word (magic). Get Denny's magic pistons, and Chads magic governor spring, and you should have close to 200 HP (each should be worth a 100HP)
ChadS
01-26-2006 17:55:32
 Re: More power for a Farmall M in reply to 5 letter words, 01-26-2006 12:05:03
They dont mix. No magic in that at all. Got a huge pile of his stuff in the scrapper. Want some parts? HAHAHAHA! Chad
B BARENIE/sm-53
01-26-2006 07:03:18
stock stroke with custom pistons 4.34 bore to 4.375 bore, might not be able to push the latter.
Professional builders can pull low 80's
and that is a real number !
