case 900 puller
caseguy
01-27-2006 09:42:04
interested in building up a case 900 diesel. Can I put 1030 sleeves and pistons in the 900 block? Can i put 1030 heads on the 9oo. Any thoughts or ideas would help. thanks
Doug Boll
01-27-2006 13:37:59
 Re: case 900 puller in reply to caseguy, 01-27-2006 09:42:04
If I was going to bore it I would put in 504 sleeves instead of the 451 sleeves, use a 4 5/8 MM piston. This setup will make decent power on gas or use a 30 series block and 70 series heads for a diesel
500 puler
01-27-2006 10:11:08
You can put in the sleeves and pistons if you bore the block out to fit the sleeves. The heads wont inerchange they have a different bolt pattern. If you are wanting high HP go with gas the diesels are not efficient power makers.
caseguy
01-28-2006 08:37:18
 Re: case 900 puller in reply to 500 puler, 01-27-2006 10:11:08
thanks
